Mihir
- Feb 3, 2022
- Milton Keynes
- ZS EV
Wanted to check if there is a way to use the front demistifier without turning the heating on? The reason I ask is the rear demistifier can be used on its own without the heating turned on. I assume it uses the 12V battery for the operation as I do not see the change in range when its turned on. But whenever we start the front one, it always starts the heating(set at auto) by default. Can it not work without heating like the rear ones do? Do the front ones also use 12V battery or HV batteries?(Heating does use the HV, its clear from the range difference once heating is turned on). I am using RainX products for defogging etc. But wanted to learn/understand if this was possible to control/manage it from within.
There may be science behind it too but any ideas or inputs will be useful behind the understanding of it all.
