V2L cable not working on MG ZS EV (merged)
I am not saying that you do not have the V2L function because of the battery chemistry on the standard range model, only that the charge level setting screen does not work, it only works on the LR models. I too do not have a panoramic sunroof on my 2023 Trophy Connect but it doesn't bother me.
Ps ,the EVCC is mounted on front nearside chassis member below the 12 volt battery if looking in bonnet from front right side low below headlight, near wheel arch.
Anyone had any luck getting the EVCC replaced on a vehicle released after the spec apparently changed. I got a 73 plate ZS EV LR Trophy in Feb 2024 and V2L doesn't work. However the spec I was given at order lists it as a feature.
If you have it in writing, see if there is a clause in small print which says specification may change without notice. If there isn't then you are in a good position to ask for it to be added.
I gave the dealer a detailed list of must have and wants. That's why in June 2023 I went for a late 2022 Trophy model with V2L, LR battery, run roof etc. I still had to get mine modified (see above) which the dealer did quickly without issue.
From MG website
2022 specifications until April/May 2023:
and May 2023 onwards specifications
specs were changed in May 2023, click on my earlier post to see attachments.
Yes it is an item that should work , seems some cars were fitted with incorrect unit. please look at my previous issues you will find info about the replacement which should be done under warranty, Mg Bournemouth did mine, very helpful.
Glenn
Can anyone confirm if 11313413 on a trophy lr registered late sep 22 is compatible with v2l?
I have a cable that I made up for use with my mg4 when I had it and it has a 470 ohm resistor in it.
It's says discharge connector connected and then discharging but never actually works and then flicks to saying charger connected
