Which battery charger do you use in between your V2L connection and your home battery ?
It's a cheapish 4 kW all-in-one off-grid hybrid inverter I picked up some years ago. A type of Voltronic clone.
I used it as a way to provide backup power for the home when coupled with some ex data centre batteries I also picked up for not a lot of $ along with some PV I put on the garage roof. Coupled with Solar Assistant and integrated with Home Assistant, the control is amazingly flexible and programmable.
I've since (2 years ago) replaced it with an 8 kW unit and LiFePO4 batteries which power the home at night (except for some high power stuff). Keep the lead acid batteries as my reserve capacity.
The old inverter wasn't doing much so I have now set it up to act as a supplementary charger if/when required. Mostly to enable the EV to provide extra redundancy. We get a lot of power outages, this is those lasting for longer than 5-minutes:
But since we also now get free grid power a couple of hours every day, if the day is poor for PV production I see no reason not to take advantage of it. Dump extra into the car and then let it supply that free energy to the home via the home battery.
It's not something I'll do regularly, just during these poor weather periods. Our district has been on flood watch over last few days and that comes with an increased risk of power outages, hence I liked to preserve battery capacity where I reasonably can. The rest of the occupants have no idea, they just carry on as normal.
I see my MG4 (64 kWh Essence) did cease discharging when it reached 80% SOC, right at ~ 7PM, so that extended our home battery coverage by several hours.
The weather improves from tomorrow so our solar PV will be able to charge the batteries OK. I have 11 kW of grid tied PV and 2.2 kW of off-grid PV.
