Vehicle settings shortcut buttons
ProfMartin
Leics.,UK
MG4 SE SR
The EV4 User Manual says:
"5 Right Shortcut Button. The user-defined function of the button can be set to AC or SRC in the vehicle settings."
and
"6 Left Shortcut Button. The user-defined function of the button can be set to vehicle control, 360, etc. in the vehicle settings."
  • Can anyone explain how you set these, what you can set them to, and what SRC stands for? (I assume AC means Air conditioning.)
  • I would like my car to default to ECO mode rather than NORMAL mode. Can I set this with the Left Shortcut button? If so, how?
SRC = Source, i.e. which media device will play. I have my right button set to AC.
Left button options depend on which MG4 model you have. Settings are configured via the menu on the Infotainment display - I can't remember which button option it is under (car?). In my SE SR the options are to see the summary control panel or to select AA/Carplay. I rarely use the control panel so I have mine set for AA.
The car will (or should) always default to NORMAL and Regen 3. If you have a Trophy then you can set the left star button to change the drive mode.
    Votes: 935 77.6%
