Voice Command List
MG - Show me the sky
Of the nearly 100 direct commands that the car understands, only the window commands don’t work in the UK version of the Trophy Connect.
I think someone else on the forum has taken the time to try them all out.
It is there. As is “go to office”
I checked the commands in the list and all work apart the 4 commands related to the windows open and close.
The “I want to see the sky” is a good one :)
Even “Find Gas Station” works. I tried “Find Charging Point” and that works as well.
Hi Dave and others in this chat. I'm new to this forum and have recently bought an MG4 Trophy and would like to use voice commands, but when I search on Google play store I get ... MG voice commands is not available because it was made for an older version of ..... I assume it means an older version of Android. Could someone publish the full list somewhere so it can be referenced please
Any good ??.
Any good ??.
Fantastic. Thank you so much
I've just got an MG4 Trophy and have tried Hello MG, Hi MG, Hey MG, ** * MG, but there is only a stony silence. If I press the steering wheel button I get a prompt but it doesn't seem to understand anything I say or just gives answers to do with random map locations if I'm lucky. I probably wouldn't do much more than ask the satnav to go home or play music, but it's really odd. I've checked settings etc. Maybe it just doesn't like me. (It doesn't like my wife either). Am I missing something? Do I have to train it somehow?
It does have to be turned on in the settings.
From my MG4 Trophy - a Guide
  • Press the Voice command button briefly on the steering wheel (top left button).
  • A screen will appear which has the message, ‘I’m here’ and you will be asked for a command.
  • Press the ‘?’ button to see a screen of ‘Something you can ask me’.
  • ‘Hello MG’ should be turned ON (11.5.6) to use the voice for activating voice commands
  • Press the ‘Voice command button’ for a longer time to get voice commands for Android Auto or Apple CarPlay.
All settings are correct but the voice system is malfunctioning, definitely a case of Hal. I think it will need a reload. Thanks for your help anyway!
Just a thought, have you checked the volume settings, it may be set very low.
Is there a volume setting for the microphone, do you know? The MG voice is a bit choppy, cutting out sometimes, but you’re right I don’t think it can hear me. It certainly sounds rather terse!
Not sure but I was thinking maybe one of the other settings might affect the volume of the speaking voice and you're not hearing it.
