Winter charge
Sean2361
Wigan
Hi all so last night charged my mgzs ev this morning it had only charged too 152 miles done this a few times now. Only 6 months old is this going to last all winter. Great in the summer 163 miles I know battery’s don’t like the cold but to lose 11 miles "? Can anyone give advice thanks in advance
Coincidentally I'd also charged my car overnight (granny charger) and noted it estimated exactly the same range as you. I put it down to the low overnight temperature of 3 degrees and I'm expecting the figure to creep up a bit if it gets warmer later on but, as you mentioned, winter range is never going to be as good as summer's.
Have you reset the accumulated trip meter and left it in N with nothing switched on ?
yes I have done that each time still does the same must be the cold weather. And the condensation each day is ridiculous
That only seems to work when the weather is warm with mine.
I've just done my monthly 100% charge and balance and got 154 miles before and after resetting the accumulated total. Also Battery voltage was 455V (old BMS), when it's warmer it goes up to 456V (456.25V on the app).
FWIW, my 6 mile trip this morning took 10 miles off the GOM at 2.8 m/kWh.
Just wait until you rapid charge when it’s about zero centigrade- and find the car will only charge at mid 20s kW! Be warned ……..
As far as the condensation is concerned, the ZS EV was probably the worst car we’ve ever owned. A contributor to getting rid of it in fact!
Is it anything to do with the glass sun roof, or is it also the metal roof models?
I wondered if the sunroof had anything to do with misting up and whether closing the blind makes any difference, but it doesn't seem to.
