Worst car I've ever had
3-phase AC charger points are not so common in the UK ... certainly not in the domestic (home) setting, as most properties are fed by a single phase supply so 7kW wall boxes are generally fitted. 3-phase AC charge points may be more prevalent in places like supermarkets or work places.
OK and MG4 Trophy and XPower do not have a 3 phase 11kW charger with you.
The early (phase 1) Trophies had the 3 phase 11kW capability. There is a thread from November
2022 showing a car charging at ~10kW. See below:
And another much the sameView attachment 13168
Yep, with a proper 3 phase cable it's 11kw, and I believe it's here to stay and not just the early ones.
There was much comment that is was just the first few, it seems to have stayed and be present on more recent ones without the driver drowsy camera.
Not in the home setting no. But in public it isn't that uncommon to find 11kW or in the case of Fountains Abbey where I was at the weekend 22kW
Based on what exactly? None of the 'faults' highlighted by the OP is EV-centric
Are you for real? What charging problems do diesel cars have?
except the Charging issue’….
Also please show me on instance of all lights in an non EV going out while driving.
Used to happen in my Ford Escort - the stalk to control the lights had a common fault with the contacts slowly wearing out or some such, and they would flicker or go out while driving. An easier fix back in those days though, of just replacing the whole stalk/harness piece that sits above the steering wheel.
I have to say though we have only done 700 miles since delivery of our Trophy LR we have had no faults. We were aware of the problems some owners have had but with the 7 years warranty we weren’t worried. Problems with new cars happen our firs new car was a 1973 ( yes I’m old ) had to have a new engine at 500 miles our next was a Vauxhall Chevette that wouldn’t start when cold, next came a Fiat you could watch it rust , in fact all our new cars cost money our last car was a BMW 220 after a month the battery failed covered by warranty but took 3 attempts to get the dealer to replace, then after 4 1/2 years the wiring loom failed at the back £500 cost at my local garage.
The point I make most cars have problems some more than others. You could jump out of the frying pan into the fire. Sort it out and the enjoy it .
    Votes: 931 77.6%
