- Jun 13, 2022
- Location
- Paignton, UK
- MG4 Trophy LR
If it does get nicked, maybe LKA will act as a sort of on-board police and force them into a nearby hedge? ?
You must live in a low crime area. They'd nick the pole as well in some parts.On a lighter note I attach my car to an electric power pole for anti theft measures View attachment 22794
Yes the keys only work in a short distance and even directional, but what the relay attack does it bridge the distance so the keys are in the house but the device picks up the signal and then transmits it to the other party standing by the car who then send the signal to the car, so the car believes the key is within the 1.5m and lets the button unlock the doors, then it believes they key is inside the vehicle and lets it start.I understood from the MG manual that the keys had to be within 1.5mtrs of the car for the keyless operation to work. This thread sounded a bit concerning, so I've just made a very unscientific check by moving my keys towards the car, and mine didn't indeed work until almost exactly 1.5 mtrs from the button (i.e. not the closest part of the car). Have others found this not to be the case, or does the range perhaps deteriorate or change with age?
That does not take into account relay access theft where the signal booster has to be within 1.5 meters of the key and the person trying to steal the car can be further away.I understood from the MG manual that the keys had to be within 1.5mtrs of the car for the keyless operation to work. This thread sounded a bit concerning, so I've just made a very unscientific check by moving my keys towards the car, and mine didn't indeed work until almost exactly 1.5 mtrs from the button (i.e. not the closest part of the car). Have others found this not to be the case, or does the range perhaps deteriorate or change with age?
So this is why the faraday box is required so the signal from they key cannot be picked up by the attacker
Some key fobs will stop sending the signal unless they detect movement, I dont think the mg ones do this.
In theory if your keys are more than 1.5m from an outside wall then the thieving scrotes won't be able to use a signal booster to open the doors and pinch the car. To be on the safe side I keep my keys in a Faraday box.
Thanks all; now I understand the concern ... I'm afraid I'm new to this level of modern technology in order to get into one's car - and certainly to the 'sophisticated' level of thievery used these days. Perhaps simplest is for us to move the key tray farther away from the front hall, and/or alternatively to go and find that old vintage cocoa tin ... but then perhaps those 'bar-stewards' will just come up with a super-booster-booster with long-distance scanners and goodness knows what else that I am sure I will never understand.That does not take into account relay access theft where the signal booster has to be within 1.5 meters of the key and the person trying to steal the car can be further away.
I tried this, and it worked, even though it said my car was in Brussels!From the app it's in the "Find Car" section on main MG tab.
Can I assume by 2FA you are referring to two-factor authentification - the totally necessary but equally horrible bain of our present times? If so then - whilst I fully respect and certainly don't quibble with your reasoning in life today - it has to be viewed as one of the most incredible suggestions I have heard for enabling access to your own vehicle. Perhaps it should apply to our front doors too, in all reality? Just a very sad indictment of our times, I guess ... I am just too old for it all.If the connectivity with the car were more consistent then the car could use 2FA to request authorisation. This function could be enabled where there was a worry about stealing.
Quite remarkable! - I got exactly the same response when I tried a few days ago ... but I didn't see you there! So what's so special to MG about Brussels, I wonder???I tried this, and it worked, even though it said my car was in Brussels!![]()
Perhaps incredible but not impractical. And, no, it should not be applied to our front doors because those, unless yours is different, are protected by non-electronically operated locks and thus immune to relay attacks. Hence police advice to add a mechanical steering wheel lock if you are worried about car-theft because that is harder to deal with than using a scanner from the dark web.Can I assume by 2FA you are referring to two-factor authentification - the totally necessary but equally horrible bain of our present times? If so then - whilst I fully respect and certainly don't quibble with your reasoning in life today - it has to be viewed as one of the most incredible suggestions I have heard for enabling access to your own vehicle. Perhaps it should apply to our front doors too, in all reality? Just a very sad indictment of our times, I guess ... I am just too old for it all.
And it always seems to be the building next door to the Eu Parliament. Why?I tried this, and it worked, even though it said my car was in Brussels!![]()
