Lovemyev
Distinguished Member
- Jan 23, 2021
- Location
- N.Wales ZS EV ( Gen 2 ).
Yes - A 12 volt jumper / booster pack is one and the same thing really.Or do you mean a 12v battery booster that's self contained?
A much smaller version of what the recovery people would use, when you report a flat 12 volt battery on your car.
These jumper packs do the same job as using a pair of jump leads, powered from a second vehicle.
Definitely a worth while purchase IMO.
If you want to carry out a trickle charge on your 12 volt battery, make sure you are using one of the more modern “Smart” chargers and not one of the older type battery chargers.
Smart chargers are able to run through a series of checks on the battery and then set the required charging rate that is best suited the present condition of the battery state.
