2021 Speakers specification
jhunterwu
Bergen, Norway
Do we have knowledge of what type of speakers we have in a stock 2021 MG ZS EV vehicle?
What brand, how many speakers and how many ohms? Also frequency range.
Probably unbranded, probably 4ohm, (you can measure with a meter), and probably not very good. Any reasonable branded item from a car audio place is likely to be better.
Good luck!
So we have full tone in the front doors and back doors and then high frequency in the window, so six speakers in total?
Found a review that says "When it comes to its audio configuration, the six-speaker system has a 25-Watt mid-bass driver within each of the four doors and a 25-Watt tweeter within both of the A-pillars."
It's only 25 watts? I have a sub woofer added only with its own amplifier, but the mids are quite high for 25 watts;)
In actual watts you don’t need much in a confined space. In a 12V system matching into 4 ohms the limit is about 25 watts. In practise with 100mm speakers the actual limit is probably less.
It seems the tweeters and mid-bass are wired together.
I get sound from both using B3/B4 and B5/B6 on the ISO 10487.
There is some sort of crossover inline? Where is the actual wiring taking place?
Have you looked at the in-pillar tweeters? They may have a capacitor attached (in-line).
