Air Con cutting out on Cold Air setting
ChrisT
Brigg
Anyone had their Air Con cut out sporadically when on Cold Air, Snow Flake button on, setting.
Cold Air is being produced but it cuts out sporadically with the whole air con stopping.
It then will only restart if the Cold air button is turned off and then the air Con button turned off and on.
My first thoughts are refrigerant gas.
Nope ice cold air no matter what setting. Is it hissing? That’s usually a sign the gas is low. Back to dealer I would suggest.
This does sound like it could be a high pressure or low pressure cut off then resets itself when you restart the car the fact that it starts working for a while it would be more likely to be high pressure
