Anyone painted their wheel trims?
sgt4hed
Gloucester
Along with the vehicle wrap, has anyone had a go at painting the wheel trims? I have a white ZS EV arriving in a couple of weeks and am tempted to gloss the trims in black completely alongside wrapping the grill in black, lower sills, roof, mirror caps and killing the crhome.
Have done in the past came out good the surface will need a light key then plastic primer then paint and clear coat probably 2k as it's tougher if you spray them flat runs should be non-existent
You could always get the wrapped aswell then you have the option of just peeling it off
Or give this ago Amazon product ASIN B097TB8HN6It just peels off
Here is a vid obviously you don't need to do all the masking just pop off the hubcaps spray black add clear coat if you don't like peel it off
Forgot to say you can use it on your Chrome trim could work out cheaper for your grill to?
I would use a big plastic sheet and just make a hole in it where you want to spray it minimum masking
