Audio equalizer settings
Kazza
Sandnes, Norway
What is your prefered equalizer setting for your audio system ?
I am struggling a little with too sharp audio and was hoping some of you might have some tweaks for the equalizer. I have the exclusive edition with 6 speakers.
I followed the settings in this video and it sounds pretty good to me.
Thank you for the video. I have set It to this now and feel its balancing quite well. Volume has to be a bit higher with AA but seems to be sounding good otherwise.
Here are my settings. You will find that switching Loudness ON can provide good output if you are into music.
When setting it up closing the windows makes a big difference.
So you turned it up to 11 :)
Not the volume, no. Under the Volume settings, you will find Loudness. Though I do not understand the intended use, I have observed that it music sounds better with Loudness on.
I'm no audiophile but you just moved all the equalizer bands up. That is effectively turning it up, not tweaking.
The settings in the video actually tweak the sound with settings of +3, -1, 0, +2, -2, which is pretty good.
Thats a luxury I enjoy only when the Mrs. is not with me!
I'm the opposite, mine's like background music usually between 7-11 volume, the missus is like a rolling disco, deafening, headache inducing loud. ?
Yes, I turned all of them up because it sounds better to me. I suppose equaliser settings need not be static, you can set it up the way you like your music played out.
I prefer to have a gain across the range, but more towards the lower and higher frequencies.
I will try the settings suggested in the video later. Thanks
In theory that is true but in reality, I have also noticed that it does seem different.
