Breakdown/Emergency Kit
Ian Key
Distinguished Member
Derby UK
MG4 Trophy LR
Gone are the days when I used to keep a selection of tools, wire, rope, WD40, selection of fuses etc. in a small toolbox in the boot together with a knuckle bar with a wheel nut socket attached just in case of a breakdown.
What do you keep in MG4 in case of a breakdown or emergency?
I have a battery booster pack, 10mm spanner, torch, florescent jacket, old waterproof jacket, granny and a 22kw type 2 cable.
You keep your Granny in boot???:eek:
On a slightly more serious note, I unloaded polystyrene spare wheel, replaced with space-saver wheel, scissor-jack { god bless Ebay } microfiber cloth { screens finger-prints cleaning } microfiber pad on a handle { inside windscreen defogger } etc
and recently looked at polystyrene spare wheel again, and to my delight, noticed the MG air pump o_O. So rescued it from garage burial site. And installed it in the boot(y)
After 2 mismatched keys ordered online I can confirm that this key 1693946319252.png
has an MG4 compatible spade. Engraving costed approx 8 eur.
Should be in a place where others can reach it in case you cannot get in/out of your car
HU100 is the blade code, and the length is (small bit) longer than the original, but that do not matter.
The engraver said that a lot of these aliexpress blades are such bad quality that engraving will ruin the blade quick, but this one is ok quality.
No i have no stocks in the company and this is not advertisement but compatible blade check :)
Which reminds me that any CAN bus hack is of course easier when you can get into the car so do not leave your key unattended.
I actually have a tyre puncture repair kit, a plier to pull the nail/screw out, and a jack( it should be easier to rotate the tyre to get at the offending screw! And helps to pump the tyre up if tyre is off the ground.)
PS: maybe get a latest Huawei Mate 60Pro which could make satellite calls should you be in the middle of nowhere!?
    Votes: 911 77.7%
    Votes: 171 14.6%
    Votes: 90 7.7%
