ElectricBenSolar
I remember having exactly this when I first picked up my MG5 a couple of years ago, I couldn’t work out why it was happening.
If I remember rightly I had turned on ignition switch without pressing my foot down on the break. Sometimes this happens and the break stays very stiff. Needs pressing again to activate. I was still learning the car back then. Like others have said might well be this interlock. Look on the dashboard it should say there if it has correctly started up and engaged the main battery (a yellow multiple battery sign shows when it hasn’t - sorry I forget the name of it).
There are definitely some quirks when it comes to the systems, if you do things in a certain order it’s fine… but in the wrong order, it doesn’t work or doesn’t do what you expect them to do.
I quite often have to reboot the infotainment system as it just stops working with certain things like Bluetooth or phone calls and audio etc. press and hold the home button for around 10-15 seconds and it will restart. Seems to sort the issue.
