jon0881
Yes. I agree. My SESR is close to arrival and if it doesn’t charge at the speed advertised it will be going back until it does. It might not be a problem now but on a long journey you will feel that extra wait for sure
That’s still 25% slower than advertised.Hi Afterburner et al.
I've just done a little experiment with my SE SR - I travelled at pace on the motorway, then came back via country roads, stopping at a Fastned 350kW. It was 7 degrees centigrade, and I went from 15% to 85% in c.42 minutes, peaking at 82kWh. I stopped at a village once I came off the motorway to enable 'Intelligent Battery Charging'.
THE KEY THING IS TO PREPARE FOR FASTCHARGING...
1. Go to the Charging Panel from the Home screen >
2. then the 'Energy Consumption' panel >
3. then press 'Intelligent Battery Charging' so that it is on.
This warms up the battery to be at the optimum temperature to accept fast charging. It also uses energy to do this, so best done when one is close to a fast charger. I did it about 10 minutes before I arrived at the Fastned station.
I'm guessing with more planning and warmer weather, plus a lower state of charge on arrival, the charging speed would be closer to the quoted figures. Will continue to collate date.
Screenshot attached - it appears to step down the charging rate at 60% and at 80%. Still faster than the i3, which is my point of reference.
Thanks so much for the in-depth charging procedures, battery pre-conditioning, and provided charging curve, this is, I believe the very first charging rate I've seen online about the SE SR, world-wide. This info is crucial. Thanks a bunch @Sparkles !Hi Afterburner et al.
I'm afraid it's looking more and more like a case of false advertising...That’s still 25% slower than advertised.
It's to be found under "maximum rapid charge capability, DC" in the leaflet you kindly provided ?Has anyone actually seen any MG publication to say the SE SR will charge peak 117kw? on their site they only quote 10->80% in 39 mins.
EDIT: https://www.mg.co.uk/sites/default/files/2022-10/MG4-EV-Brochure.pdf
I expect this is under ideal conditions. It is also possible that MG have the rate currently limited on the SR for some technical reason.It's to be found under "maximum rapid charge capability, DC" in the leaflet you kindly provided ?
Unlikely to be coincidence. Could be software limited to the same as MG5 while they debug faster rates, or even that they forgot to update this part of the software.sorry i call BS until proven otherwise. If a tesla using the same chemistry can rock up and charge at closer to max speeds then thats not fair. It cant be a coincidence that the max rate on the MG5 is exactly the same right?
Really is such a shame they haven't improved their communication. Would make such a difference to how people perceive their approach to these problems.No doubt. In future they should caveat it.
Unlike MG not to share it with the owners. ?
You are right to feel like that... we are just speculating on cause into the great MG communication vacuum. Hopefully someone with the problem can escalate this via their dealer to get an answer.well as i said, it is really strange that the charge rate of the mg5 and lfp mg4 and pretty much identical.
i assume that it is just marketing and therefore misleading
you got to have the right temperature and under the ideal circumstances like air pressure and only on mondays and thursdays you should achieve the peak charging rate???
meanwhile the nmc mg4 can charge at max speed without efforts - somehow i feel mislead and cheated
There will be I'm just summoning up the courage to do my first one . Just been using a granny for now!115Kw seems a bit high for a LFP battery. Strange, that there is nobody testing the standard range one.
Has she complained yet?There will be I'm just summoning up the courage to do my first one . Just been using a granny for now!
Ha!! No I keep her well fed on wurther's originals!!
I've read some reports that the Model 3 LFP are showing surprisingly large degradation, maybe pushing batteries towards 3c in charging is not for the best despite the convenience ?sorry i call BS until proven otherwise. If a tesla using the same chemistry can rock up and charge at closer to max speeds then thats not fair. It cant be a coincidence that the max rate on the MG5 is exactly the same right?
