richbaseley1
Yeah manual charging works perfectdoes a manual charge start ok if the vehicle is already locked when plugging in?
It has the same issue no matter where I do the schedule unfortunately car or charger. I have found one thing and not sure if it makes sense to anyone. The past 2 nights I've had successful charging. The only difference I made was, I set battery preheating 30 mins before the charge started. I've tested again today without battery pre heating and I've had the 0.07 kW issue again. Anyone ever seen battery pre heating needed to charge properly? Wondering if actually it wakes up the car to allow the charge.On mobile so unsure what version of the mg you have.
Can you schedule in the cars settings? It's under the main menu, battery then tap on the cog I believe as well as set limits if on a trophy.
It might be worth clearing or adding schedule via the car only and ignore the charger just set it up and connect and let the car do the charging?
It may be that your car was going to sleep in that last half hour, and any activity (e.g. lock doors) at that time might have woken it up. Just a thought.The only difference I made was, I set battery preheating 30 mins before the charge started.
I’m using a Evnex charger.….. I have is a Project EV Apex charger.
Project EV came out and swapped the charger out for a brand new one which has the same issue. I really feel like its an incompatibility between the two. I guess I'll not know any more until the car has been in to MG. Any other tips from people are always welcome though as its a massive painHave you tried a full disconnection and reset of your wall charge point ? I suspect it's that or some settings on it or just incompatability as you say, as the car charges and schedules OK on other chargers.
Seems decent so far. The only downside I've found is I only seem to be able to change the charge % from the app and not the car anymore but not too much of an issue. Other than that it's all goodI think you're the first person here to confirm having 1300R63. Anything obvious about it? (Good or Bad)
Thanks mate. The firmware updates sorted this out for meI have a charger that look suspiciously like a projectEV unit (vchrgd7). I once had a problem with scheduled charging. Long and short of it, I isolated it to powerline networking kit in my house. There is a thread somewhere on here where I posted.
I removed ALL powerline networking kit and voila problem gone. Not saying it is you issue but worth a mention.
Something in my memory says you have to slide the %age charge bar in the car rather than tapping the screen. Have you tried that?Seems decent so far. The only downside I've found is I only seem to be able to change the charge % from the app and not the car anymore but not too much of an issue. Other than that it's all good
