Rolfe
Moderator
- Apr 10, 2023
- West Linton, Scotland
- MG4 (2022-2025)
Thanks for that, very kind.
This is so nuts I still feel I must be missing something, but I've been through every setting I can see, and can't find anything. And I read someone else saying he didn't know how to stop his battery charging on the solar.
Rolfe wouldn't gain anything by doing this?Have you considered switching off the solar panels if you want to export and use your battery on a sunny day?
Yeah, I realise that now. I think the Timed Discharge is the function she wants, it's just getting the setting right. I think if Rolfe sets the Timed Discharge from a time in the morning when the panels start to generate, to 23:30 when the off peak kicks in, that should make the panels export.Rolfe wouldn't gain anything by doing this?
Yes, this is along the lines of one of my suggestions.I don’t have this system so not sure if you can specify to charge the battery to different percentages at different times of the day or whether you would need to manually change limits in the morning and evening but this is what I have been thinking.
Sometime after 05:30 (ideally before Solar generation) could you set the battery charge limit to say 50%? As the battery will be above 50% when the panels start to generate the solar output will be exported.
But if you set it to charge up to that amount, then if it is above that (from overnight filling) then it won't drop down to 50%. It will only go up.
So it would be necessary to set it to export down to 50% instead.
I expect that soon enough your solar will drop off and you won't be so worried about it. The solar will just top up the battery, which will then get you through until the next evening session.
Then when Spring comes around you can focus on export again.
I think you have summed up the issue perfectly with this statement.That's totally not the case. The solar is always "costing" me 15p if I use it, as opposed to the contents of the battery - if it was only being filled from the grid - costing me only 7p. Putting the solar into the house or into the battery is basically costing me 8p more per kwh compared to using off-peak power from the battery. That isn't going to change just because it's winter.
Most inverters that Ive seen and definately on my Growatt theres a 'grid first' and 'battery first' options that can be set with a time schedule, this sounds like what youre youre trying to achieve. What make and model of inverter do you have?I don't think that would work - though I have been wrong about things before. If the battery is below 100%, and there is more solar than the house needs, then the battery will take that solar. No way to stop it that I can see. Also no way to get the house to use the battery in preference to the solar.
Yes, they updated the app several times. Older versions many not even work at all any more.I watched that entire video about the system, but it's a year old, the relevant part of the app looks completely different now, and the maker of the video doesn't even mention the issue, probably because he's on Intelligent Flux, not Intelligent Go.
2. It's a bodge-up, a real one. All day, if I use electricity, I'm thinking, this is costing me 15p/unit, when I was so sure when I got the system that I'd only be paying 7p/unit. I'm getting it back later, but it feels all wrong.
I have emailed GivEnergy, so we'll see what they say. I mean, how long have these tariffs been available that mandate this way of operating? Surely they should have it covered by now.
I think I just don't get your comment about the house "not taking any solar."I just want to be able to set the system so that neither the battery nor the house takes any of the solar generation, then forget all about it. People with different systems seem to be able to do it, what exactly is GivEnergy's problem?
John, when I said I was happy to let the car charge on the solar as it was set up (until I got the export tariff), simply setting the battery not to use more than 93% in the morning and cancelling that in the evening, you seemed to think that was way too much intervention. I really didn't mind that though. It's this mad carry-on with the export timing that's doing my head in.
I didn't get it at first, but see Rolfe's previous post:I think I just don't get your comment about the house "not taking any solar."
The solar is effectively free now you've got the system. It can either go to the house, battery or grid.
You want it to go to the grid to get the export payment? But the house has a draw, and you don't want that to come from the grid (which isn't even possible, you can't give and take at the same time down the same wire), so it has to come from either the battery or the solar. What difference does it make if the house is getting power from the solar vs. the battery?
I think maybe I'm misunderstanding something.
There used to be a battery pause option on an earlier version of the givenergy app but I couldn't get those buttons to work reliably and they removed it from recent versions.
