Bazarooni
At about 3000 miles from new, my MG5 has started to develop a clonking sound when the drive picks up from rest, particularly pronounced starting on a hill. Seems the warmer weather recently has eased it somewhat, but is definately getting worse, and even clonks on first brake pedal press now too. It's not the handbrake actuators as the noise it at the front wheels, and not within the drivetrain as far as I can tell.
I jacked up each front wheel and found enormous play on the inner CV joints both sides, no play on the outer ones (wheel side). Rotating the wheel back and forth clearly gives the clonking sound I'm getting now.
Complained to dealer service, who didn't understand, so asked at the first service for the clonking to be looked at. Unbelievably, the technician, who did understand the problem, said "it's normal", and wasn't going to even make a warranty claim or do anything about it. He went on about pins in the transmission, and not being able to tow more than 2mph, and all sorts of irrelevant rubbish in no way connected with the problem to fob me off, and had to force him to make a warranty claim to MG. Of course, MG are bound to reject the claim, if he actually makes it or doesn't describe the problem properly. I suspect I will hear nothing. I've had new cars for decades, and none of them developed clonking noises after 3000 miles, so it can't be "normal".
Has anyone else experienced this clonking sound on pick-up from rest? If so, what did you do about it that might work?
Thanks for any advice.
