Demisting front windscreen
It appears so, they have little tabs on them which makes them easy to remove. No idea why they would block a drain hole? Unless it’s missed from being removed during the PDI?
Just checked mine and the middle drain holes are covered with plastic, but no tabs on them to make taking off easier. Are we sure taking them off is the right thing to do?
Mine were like clear bits of plastic sticky tape, definitely covering a hole in the door. I only removed three as the one rear door was missing one. It probably came off when cleaning the underside of the doors. Someone else on here mentioned the same tabs. Will try and find the post.
Even with the holes clear, the doors seem to be quite good at holding water.
Hi- mine is the same, did you remove them in the end? I had a little go and they seemed hard on so didn’t want to peel off incase they are needed for something else?
Try a Thermal Windscreen Protector.
