Loveclose
- Feb 8, 2024
- Location
- Andover UK
- MG4 Trophy LR
OK, so after 9 months or so, I had my first public charging glitch....
Quick top up charge needed at Ionity Chobbam at the M25 services.
Ionity is linked with Eloctroverse which gives you a few pence off Ionity's rate.
I draw up to the number 6 bay...Ionity says it's free, Electroverse says it's 'occupied'.
Using the Electroverse app, the charge starts fine, and then stops after around 5 minutes with a fault indication.
It does this two further times. By the end of the third attempt, I have enough miles to get home, and do so without problem.
I charge my car overnight to 100% using my 7kW charger which was glitch free.
1) Was the glitch a communication issue with Electroverse app and the Ionity network??
Or
2) Is there a fault with my car's fast charge connector?
Not had issues with fast charging before. I intend to run my car's charge down, and then test the fast charge ability again using the Tesla chargers at Amesbury.
Thank you for reading this....any thoughts welcome over reliability of Electroverse too!!
Or
