Alb
Moderator
- May 11, 2021
- Solutions
- 7
- Location
- MG5 SR PFL
That can be a dangerous "feature".
That's just crazy talk.Could be worse, we could be in the group of people that have a button to open and close their boots. Imagine that!
Or sometimes it's just a case of turning the rubber stops in (or out) a bit.Does this imply that the boot catch is slightly out of adjustment or the securing bolts are loose, allowing the base plate to shift ?.
If reopening the tail gate and slamming down a little harder mitigates the problem, then surely the latch needs adjustment by a few mm.
If the catch is too far back, then only slamming the tail gate will latch it correctly.
If the latch is not making the full latching process, it will put the warning light on the the dash panel.
Adjusting the tailgate should be a “Gravy” job for most Tech’s !.
Yeah - This could work !.Or sometimes it's just a case of turning the rubber stops in (or out) a bit.![]()
