Lovemyev
Distinguished Member
- Jan 23, 2021
- Location
- N.Wales ZS EV ( Gen 2 ).
I am not familiar with that area sorry, but it looks very nice I have to say !.I found on my trip to Bach Wen (Do you know it?) ECO mode gave no Air Con at all!
In fact it was dangerous whilst going over the pass from Bala the temperature went down and humidity up but it couldn't keep the windscreen clear and it misted up no matter what we did!
At least the I-Pace gave me, the driver, the choice to either have effective Air Con or range. It was my call.
You could play with temperature and fan speed and see the effect on the GoM!
The Bala lake and its surrounding areas are only about 30 miles away from our home address.
You are correct, in Eco mode you are only receiving a very small amount of chilled air into the cabin.
When the weather conditions are hot like this week, the warm ambient air is past through the HVAC unit, and it has very little effect in cooling it down.
It's effectiveness can hardly be felt really.
Increasing the cooling temp even more, will chill down the air entering the cabin, but in Eco mode it is fighting a losing battle TBH.
When the ambient temperatures are this high, then only MAX cooling will bring down the cabin
temperature really quickly.
Normal mode will allow this, but it's use does have an affect on the range.
I find to get the cabin temperature down quickly, put the HVAC unit into recirc mode.
This way it will shut off the flap in the HVAC unit, that permits hot area from entering into the unit from outside and will slow down the cooling process.
The negative effect here is, that this can increase the risk of "Fogging" of the glass.
As soon as you see this, release the recirc button.
The requirements of Max cooling or Max heating for that matter, while trying to conserve range by using Eco mode, don't go hand in hand really ?.
