DavEV
Pretty sure it should defog all of it like every normal car in the world, and not just a part of itThe bottom couple of elements are the radio aerial.
Bottom elements are the radio aerial, like he said and like many cars in late 90s, so it won’t defrost down there. Yes, it is a compromise, penny pinching where it actually matters and I wish it were different, but one of the reasons the car is so cheap.Pretty sure it should defog all of it like every normal car in the world, and not just a part of it View attachment 12876
What are you going to see soon? It’s the aerial at the bottom. Has made zero difference to me….That'd be a very poor design, and something MG dealer didn't tell me, even after I sent them the same photo.. we'll see soon
Nothing, just when I told the dealership, they didn't tell me it's by design, and that they'll check when they'll have my car to check the other issues (heating not working properly and possible breather pipe issue).What are you going to see soon? It’s the aerial at the bottom. Has made zero difference to me….
It is by design, as confirmed in this and many other threads. ?If it's by design then yes we'll live with it
But you can’t trust us lot on t’internet! ?It is by design, as confirmed in this and many other threads. ?
? True but it looks like people here know better than my dealership! ?But you can’t trust us lot on t’internet! ?
If it's by design then yes we'll live with it, and with all the other problems and rubbish infotaiment system, until we'll give up and change the car![]()
Perhaps the first reading is from when it was last used and it takes a few minutes for it to update?Two reading this morning
While I was looking to preheat.
First one shows 20 Deg inside the car.
If you then click refresh about 20 times it keeps dropping down a bit each time
Until this one
Is there anything on this car that works right ??
Every press of the refresh button dropped it a Deg or so over the space of 13 minutes.Perhaps the first reading is from when it was last used and it takes a few minutes for it to update?
You have to go on Facebook and find a Facebook fully qualified expert.But you can’t trust us lot on t’internet! ?
Perhaps the packaging that was accidentally left around the sensor has dropped off ?Heater calibration is a known issue.
Mine didn’t pump any heat out until 26C but, strangely, I noticed it’s starting heating at 21/22 now.
I’ve no clue if the MG does over the air updates, I can’t explain it otherwise.
I dont think this the case.its air conditioning. Not air cooling. With normal a.c you can heat conditioned air. It just means its warm and dry .It has climate control not A/C. Climate control cools and heats whereas A/C only cools.
You’re commenting on a 17 day old post and this has already been discussed/answered if you read the thread ?I dont think this the case.its air conditioning. Not air cooling. With normal a.c you can heat conditioned air. It just means its warm and dry .
Climate control monitors the cabin temp relative to the temperature you have set and varies fan speed accordingly .
I do apologise. (Missed that )You’re commenting on a 17 day old post and this has already been discussed/answered if you read the thread ?
