Lovemyev
Distinguished Member
- Jan 23, 2021
- Location
- N.Wales ZS EV ( Gen 2 ).
To be honest when you made the decision to order a LR model, you did so completely because it matched your usage need requirement.
So, now even considering / accepting a standard range model make no sense to me at all sorry ???.
If it does not match your original order and falls short of your usage requirements, then it is totally useless or you therefore ordered a more expensive model with a larger battery for nothing really ??.
It is their error not yours, don't make their problem YOUR problem !.
They have registered the car and it now gives them a big headache.
They need to provide you with the correct LR model or reduce the payments and offer you some type of compensation in return.
This will be more cost effective to them, unless they are able to replace the car with a LR model.
If you consider the cheaper option, first think carefully IF the reduced range will suit your needs.
