HVAC temp
That’ll explain why so many of us have to set temperatures so high for a comfortable car!
Well I was having a look at the info available from the car and noticed there's 2°c difference between FICM and HVAC
Lo & high is just 0.5°c difference to the next setting
I'm going to check mine tomorrow as it doesn't have the HVAC update applied yet.
Usually you have this offset on a ice car where the probe sits closer to the hvac unit and by the time air gets into the cabin it has been heated by the surrounding environment. On an ev it makes zero sense
The big problem here is that they've used a Celsius temperature scale. Nobody would complain if there was a dial with gradations from blue to red with no stated temp. People would just adjust it until they were comfortable. But MG for whatever reason decided to use offset temperatures that are consistently wrong. Just inexplicably shitty UI decisions.
FWIW, since the recent HVAC and Info updates I have been using 22°C as my target temperature vs 25°C I had to use previously to achieve the same level of cabin comfort. :)
That sounds like they’ve sorted the mismatch. Hopefully that’s the case for us all at some point 👍🏻
Here's my cabin settings for general comfort.
I noticed the the A/C temp variation as soon as I got the vehicle.
I'd set 22C as if had in my VW, and as it was a summers day the A/C blew cool air and I thought this was great . After a little while my passenger said "it's a bit chilly in here" which is unusual for him, so we uped the set temperature a degree at a time, and agreed that 25C to 26C was comfortable.
Now its winter, the set temp is still 26C and still everything is fine.
I was going to take this issue back to the dealer, but as I see I'm not the only one and Siteguru has suggested that there is some sort of HVAC and Info updates that fix this quirk.
Question for anyone reading this: Do I take the car back to the dealer, or is there a software update I can do myself?
When you get your car, you'll experiment with the settings. You'll soon find what's good for you. Then stick to it. Simple really. 25° seems to be perfect for me in Winter. 🙂👍
Just checked mine and HVAC set point matches FICM UI, I bet it's something they introduced during the last update. Which HAVC modules versions are you running?
I have to agree; its just a number.
OK, so its the temperature at some point in the HVAC system, but as long as the cabin environment feels good and comfortable, does it matter?
However, I think that at some point in the model's design and development, the HVAC guys should have insisted that the digital readouts reflect the cabin temperature, not the systems sensors readings.
    Votes: 935 77.6%
