Martinonline
- May 17, 2023
- Location
- Sheffield
- MG4 Trophy LR
The simple answer is to wait and it will return. Unlocking the car sometimes works. Refreshing the status a number of times sometimes works. Using the car sometimes works. ...
Clearing cache did not work. Could not log in or out, only logo screen
I uninstalled, installed again, logged in.
It's ok now
The new installation has a slightly different UI. I think it's a new update, but Google store did not say an update was needed, I had checked before reinstalling...
Correction, no the UI difference is only in the dark theme, re installation reverted to light theme, back in dark all is same.The new installation has a slightly different UI. I think it's a new update
On android go into settings, apps, see all apps, scroll down to MG iSmart and select it, select Storage and cache, clear storage (not just the cache). You will have to sign in again using your original login details.I have also tried clearing cache (although I had no such issue logging in etc.), and I have the latest (according to Google and MG iSmart) v. 2.0.7. Has made no difference whatsoever. The app needs a fundamental re-design to a far more sophisticated set of parameters to work as intended and as advertised.
I do get a display but it won't do bugger all.Do you get some display, but no connection, or nothing at all?
The server is in Belgium. I think the office cleaner sometimes unplugs it to vacuum.I do get a display but it won't do bugger all.
It thinks I'm in Belgium, which I was in April last year, but in the MoHo not the car![]()
Oh heck, the app has found me or should I say it has found where my phone is, so completely crap for finding the car.
Vehicle status is blank.
I think I shall do what I do with most of this cars software, ignore it.
Incidentally the job the car went in for, which was a small piece of trim on the nearside below the screen had broken and it was supposed to be replaced, it wasn't, the app was supposed to be looked at and fixed at that time which they said it was isn't.
Mine is 4 out of 5, after some refresh, close and reopen.I reckon my success rate on connecting is about 1:5
I don't think you are far wrong. I've never had any real problems connecting but for the last 20 hours the app times out. It's going to be an exercise in patience waiting for MG to rectify the problem...again.The server is in Belgium. I think the office cleaner sometimes unplugs it to vacuum.
I’m getting the same issue. Unlocking and locking the car didn’t help. Had to sit in it and watch it clear the screen, which took about 6 minutes with temp -4°C.I don't think you are far wrong. I've never had any real problems connecting but for the last 20 hours the app times out. It's going to be an exercise in patience waiting for MG to rectify the problem...again.
Same. Won't even scan today let alone defrost.I’m getting the same issue. Unlocking and locking the car didn’t help. Had to sit in it and watch it clear the screen, which took about 6 minutes with temp -4°C.
I've got the same problem cannot connect to the car since this freezing weather started.Hi
Is anybody having any issues with MG ismart app. When I try to connect I get message stating The remote control feature failed, please try again later.
Vehicle status etc not working same message.
Does anybody else have same issue and how do I rectify
Thank you
Hi
Could be 12v battery dropping under 12v i have a hardwired dash cam that stays on for security and ismart app will not connect if that happens..also with cold weather doesn't help battery either..Hi
Thank you
