I'll take it! ?
Septian
Bristol
Quick jaunt from Bristol to the in-laws in Abergavenny and back. The warm weather certainly helps ? ACC set to 60 on motorways and dual carriageways, with a little bit of "manual" driving at roundabouts and whatnot.
Quick jaunt from Bristol to the in-laws in Abergavenny and back. The warm weather certainly helps ? ACC set to 60 on motorways and dual carriageways, with a little bit of "manual" driving at roundabouts and whatnot.View attachment 3376
Can I ask why only 60 on the motorway?
The fan should bec12v so shouldn't affect the range, whereas the a/c and heating are a much bigger drain on the traction battery?
Hi Storm, while driving the HV battery keeps the 12 volt battery charged so does affect the range. All consumed energy comes from the HV battery unless plugged in charging. Cheers.
Yes I know but the cabin fan shouldn't be a high drain item so shouldn't have a noticeable affect on range if it has been designed/works properly
