I don't know what your prices are could be worth looking at OVO they now offer anytime charging at 10p and there variable rate is at government cap and no exit feesEon at the moment
octopus go is 10p higher per kwh than Eon
but standing charge is 2 p kw cheaper than Eon
is it best for me to switch now
I’m only going to use a granny at home over night as I only now do about 50 miles a day so I think Octopus could be my best betI don't know what your prices are could be worth looking at OVO they now offer anytime charging at 10p and there variable rate is at government cap and no exit fees
There are quite a few posts in the general room on octopus and OVO definitely worth a read
OVO good News 10p anytime
OVO anytime 10pkw charging 24\7 is now available to anyone with OVO now including new customers You previously had to have OVO drive to qualify but now open to everyone OVO have no tariffs deals right now just variable but you can still at anytime charging for free MG is not compatible but some...www.mgevs.com
What ever works for you will be your best tariff every one has different needs always good to look at all tariffs and standing charge think OVO is 34pkw 37p standing electricity 10p gas 27p standing obviously the 10p charging 24\7 is no on grannyI’m only going to use a granny at home over night as I only now do about 50 miles a day so I think Octopus could be my best bet
Thanks for your help great Forum for us new to this Technology. Trophy long range is great car worth ever pennyWhat ever works for you will be your best tariff every one has different needs always good to look at all tariffs and standing charge think OVO is 34pkw 37p standing electricity 10p gas 27p standing obviously the 10p charging 24\7 is no on granny
If you are using the granny EVSE will four hours of Octopus Go be enough time to charge up the car?I’m only going to use a granny at home over night as I only now do about 50 miles a day so I think Octopus could be my best bet
Good point that's only about 24miles ?If you are using the granny EVSE will four hours of Octopus Go be enough time to charge up the car?
Probably not doing about 30% a day on average so don’t think I would Octopus go would be enough . So it’s trying to way up if it’s still better to switchIf you are using the granny EVSE will four hours of Octopus Go be enough time to charge up the car?
Both octopus and OVO offer ohme charges at discount and other charges I only mention ohme as compatible with both companies for cheap charging in fact I think it's the only one that works for both and with no exit fees quite handyProbably not doing about 30% a day on average so don’t think I would Octopus go would be enough . So it’s trying to way up if it’s still better to switch
I was hoping that I could go on to Octopus go but you need to have a outside charger which with the 30 miles a day I do it would not be worth my whileBoth octopus and OVO offer ohme charges at discount and other charges I only mention ohme as compatible with both companies for cheap charging in fact I think it's the only one that works for both and with no exit fees quite handy
You don't need an outside EVSE just an EV and a granny unit. Have you phoned Octopus?I was hoping that I could go on to Octopus go but you need to have a outside charger which with the 30 miles a day I do it would not be worth my while
Will give them a buzz thank for the infoYou don't need an outside EVSE just an EV and a granny unit. Have you phoned Octopus?
I have solar panels and batteries. Switched to Octopus outgoing agile. This summer I'm hopeful for nigh on free charging.Eon at the moment
Might have a look at OVO myself ??I don't know what your prices are could be worth looking at OVO they now offer anytime charging at 10p and there variable rate is at government cap and no exit fees
I’m currently using a granny and getting 50 miles over the four Octopus Go hours each night.Good point that's only about 24miles ?
Can't see it the granny is about 2.5kwh X 4h is only 10kw @ 3kwm is 30milesI’m currently using a granny and getting 50 miles over the four Octopus Go hours each night.
As you say it’s all about miles per Kw and I do much better than what you suggest. Which means I get 50 miles added to the range each nightCan't see it the granny is about 2.5kwh X 4h is only 10kw @ 3kwm is 30miles
Edit the granny is 10amp = 2.3kw so it's even less
So your getting over 5mkw?As you say it’s all about miles per Kw and I do much better than what you suggest. Which means I get 50 miles added to the range each night
