joefish60
- Jul 27, 2023
- Location
- Newcastle upon Tyne
- MG4 SE SR
How do I disable LKA on the mg trophy?
Only had the car a week and struggling to find how to do itMore seriously on MG5 you do it via the infotainment unit. There's guidance in the manual, assume same / similar for MG4
Look in the MG pilot in the infotainment system which can be accessed via the car symbol bottom right of the screen. Unfortunately you won’t be able to turn it off permanently and it will come back on next time you jump in the car.Sorry lane keep assist is what I meant
Mine definitely doesn’t keep the lower sensitive setting. Running R30I found that instead of turning it off every journey, I just lowered the sensitivity and it's not as bad and it remembers the sensitivity setting so you don't have to adjust it every time you start.
Mine's on R33.Mine definitely doesn’t keep the lower sensitive setting. Running R30
That's a fantastic tip - hadnt thought of that. Thank you!I found that instead of turning it off every journey, I just lowered the sensitivity and it's not as bad and it remembers the sensitivity setting so you don't have to adjust it every time you start.
Mine is on R33 and I tried setting the sensitivity to low on all the tabs I could do that on and it doesn’t keep them all there. Next time I got in it had put some of them back on to moderate. So if I am going to have to keep setting them back to low every journey I might as well stick to what I had been doing before which was to turn the keep lane assist off and Emergency Brake off.Mine's on R33.
Mine does what yours does.Mine is on R33 and I tried setting the sensitivity to low on all the tabs I could do that on and it doesn’t keep them all there. Next time I got in it had put some of them back on to moderate. So if I am going to have to keep setting them back to low every journey I might as well stick to what I had been doing before which was to turn the keep lane assist off and Emergency Brake off.
You,ve got no hart?sorry...as a Spurs fan I was hoping this thread was about something different ?
Same here buddy it doesn't seem no where near aggressive as it was ?I found that instead of turning it off every journey, I just lowered the sensitivity and it's not as bad and it remembers the sensitivity setting so you don't have to adjust it every time you start.
Had my mg4 trophy October 2022.my LKA used to keep switched off.i took car in to mg dealership 2 weeks ago for a software update since then I can't switch LKA off unless I do it every time I use the car and it was very aggressive I took car back to dealership and complained about it and said it was bloody dangerous they have now done another software update and it is a lot better and not so aggressive. Apparently they can not turn it of permanently because of the NCAP 5 star ratingMy wife has the MG4 trophy . The Lane Keep Assist is awful, intrusive and perhaps dangerous. It has also do 2 emergency stops without reason or warning. It’s been back to the dealer twice, with no real explanation or improvement.
I have recently bought a Kia EV6 and boy is it better! The systems are so much simpler and refined. LKA is subtle and helpful. The Kia is in a different league, but nearly 20k more.
MG need to do better.
Yes, it isn't just MG but all manufacturers wanting to get the highest ratings nees LKA to be enabled each time the car is started.Had my mg4 trophy October 2022.my LKA used to keep switched off.i took car in to mg dealership 2 weeks ago for a software update since then I can't switch LKA off unless I do it every time I use the car and it was very aggressive I took car back to dealership and complained about it and said it was bloody dangerous they have now done another software update and it is a lot better and not so aggressive. Apparently they can not turn it of permanently because of the NCAP 5 star rating
Press the button on the end of the indicator stalk twice. You have to do it every day. I haven’t found a permanent solutionHow do I disable LKA on the mg trophy?
