shinyrobot
I've abandoned mine for all of December below 40%. No stress. If was fine.
HiCan anyone suggest the optimum charge to leave on the battery if the car is going to sit on the driveway unused for most of February?
Thanks
From a personal perspective,There you go. for more than 1 month disconnect negative terminal, page 291
Note: It is recommended to ensure the vehicle is
placed in READY mode for half an hour every week
to help extend the service life of the battery. If the
vehicle is stored for more than 1 month, remove the
negative terminal from the battery. Make sure that
the vehicle power system has been turned off before
connecting or disconnecting the negative terminal.
So the HV battery maintained the charge of the 12V battery. Great. I'm not sure how the jump starter could be useful, but you might need to find out what caused the drain on the 12V battery (frequent check on the vehicle status on your phone, glove compartment light...). Did you make it home/to the charger?Left ours at Canberra airport for 6 weeks after driving to the city (70km). Battery was about 70% when we let it, lost 12% in 6 weeks, 12V battery was fine.
I have a jump starter but don’t usually carry it with me.
I assumed the 2% drop per week maintained the 12v charge…car worked perfectly on the drive home. My BIL knows a Tesla owner who couldn’t start his car after a similar time parked.So the HV battery maintained the charge of the 12V battery. Great. I'm not sure how the jump starter could be useful, but you might need to find out what caused the drain on the 12V battery (frequent check on the vehicle status on your phone, glove compartment light...). Did you make it home/to the charger?
As long you happy with the result is fine, I guess it would be different if you couldn't leave the airport. Also I'm not sure whether a 6W/h average consumption is high or not, probably some expert out there to tell us. One thing for sure, I wouldn't leave my car behind lower than 70% SOC for an extended period, just like you did. Trickle charger?I assumed the 2% drop per week maintained the 12v charge…car worked perfectly on the drive home. My BIL knows a Tesla owner who couldn’t start his car after a similar time parked.
It was only a short drive from hotel nearby, so I don't think the battery had time to warm up.@tsedge 1% loss could be down to the cold weather. The battery would be warm after the drive to the airport and the loss is when the battery cooled down to the ambient cold temperature.
Modern cars don't have cap breather as such so the fuel doesn't evaporate, but petrol does go off if left for a long time.I wonder how much gas/petrol evaporates through the gas cap breather of an ICE when it's left for periods of a month or more? This won't be noticeable because of the way ICE's fuel gauges display the level. If they displayed a percentage as on EVs I think ICE owners would be very surprised to see the level drop over time as it certainly does.
If an EV simply had a 4/6/8 bar gauge as on ICEs, the drop wouldn't be noticed.
My EV has an 8 bar gauge (8 LED). It's an MG ZS EV Mark 1. I can get a SoC estimate with 1% resolution, but I have to be charging the car to see it. Just another niggle ?If an EV simply had a 4/6/8 bar gauge as on ICEs, the drop wouldn't be noticed.
Sounds like the Tesla owner left "Sentry Mode" (which runs all 8 onboard cameras) running while he was away.I assumed the 2% drop per week maintained the 12v charge…car worked perfectly on the drive home. My BIL knows a Tesla owner who couldn’t start his car after a similar time parked.
