- Sep 3, 2022
- Solutions
- 3
- Location
- Strathaven (SE SR MY22)
- MG4
I have mine set to 37.5 psi.
Maybe to be safe, I'll buy the ultimate ultra accurate digital tyre inflator from Temu and set it to 37.6 psi?I have mine set to 37.5 psi.![]()
Very interesting thread. We haven't had an issue with tyre pressures on our 23 phase 2 Trophy LR until recently.
But it's always the rear NS. Until today.
Mrs S has gone to a footy match with brother and father and I am (as ever) confined to bed with broken ankle. But I did my weekly status check. For the first time ever two tyre pressure warnings came up, but get this:
How can the system read exactly the same pressure for the rears as the fronts but flag them up as low? That I just don't compute, and obviously His Lordship (our name for the car!) doesn't, either.
As I said, the N/S/R normally pops up as low when it's cold, but it soon reads OK after a bit of driving. I guess today (in the NW where we are and the Midlands where the match is) it is very cold, so maybe the low pressure readings won't disappear with driving.
I've read what others say about ignoring the MG advice and putting 2.6 or 7 in each corner. Is that the solution here?
That's because the car is now moving and the pressures have increased just enough to take them above the trigger threshold due to the friction creating a bit of heat.The car's on the move now, but the exterior temp is still below 3 degrees (it's been between 1-2 degrees), but the pressures are now aOK.
Shrug.....
I had same issues with TP alarm some 10 months ago all I did was adjust all tyres and no problems sinceI have mine set to 37.5 psi.![]()
Not a fault. Put some air in. Many, many posts on this.Is anyone else having TMPS faults now it’s freezing cold. It’s happening on my 2 rear tyres but come afternoon there’s no issue. Only taken delivery of the car just over a month ago?
Is it though?Should of mentioned I’ve checked the pressure and it’s fine
Says it all?37 was what I was getting when I checked half an hour ago, I’ll allow some extra time in the morning if the error comes up again and go to the petrol garage and check then. Cheers for the advice
