I have all the boxes at home so will send you details later.Can you send me details how to do it it would be a great help and what model would fit
The first thing I did when I test drove the car was check out the sound system and its definitely one of the poorest sound systems i've heard so I always new I would upgrade it.I think the standard sound is a bit mediocre, I'm not a connoisseur so don't want to run to a sub, but I've had previous cars with just 6 speakers that sound spectacular compared to the ZS EV.
Is it worth just changing out the standard main speakers? Will it improve things much by doing this alone do we think?
If you just upgrade the speakers it will definitely sound alot better just make sure you spend a fair amount on decent speakers and add some sound deadening as there is none in the doors.
I'll send the picture of the box when I get in from work ?Do you happen to have the Focal name/part numbers of the speakers you swapped out please? I've had a look at the website but wouldn't know where to start!
It's all in one great little unit.Have you installed an amplifier??
I can't find the box for the speakers but I can measure the old ones if you want. I also noticed you are in Lincolnshire the guy who fitted this for me is in Peterborough MC-InCar on London road you could give him a call as he would know exactly what speakers and adaptors you would require.Very helpful, thank you![]()
hi thanks for your help, will the company fitted amplifier handle the upgraded speakers and subwoofer??I can't find the box for the speakers but I can measure the old ones if you want. I also noticed you are in Lincolnshire the guy who fitted this for me is in Peterborough MC-InCar on London road you could give him a call as he would know exactly what speakers and adaptors you would require.
Yes that unit handles everything fine. There are no problems with any extra power being drawn from the car either.hi thanks for your help, will the company fitted amplifier handle the upgraded speakers and subwoofer??
Hello Allen,Hello
Yes it can be done. I upgraded all 6 speakers to focal and a under seat sub also the focal brand. I usually do this myself but in this instance I had a independent do it for me as I had the car sound deadened at the same time. If you are just replacing the speakers it should just be door cards off and a straight forward speaker replacement with adaptors.
