I think if its really cold (- something) and you need to stop to charge, you can run the battery heater for 10, 20 or 30 mins before arriving, obviously you don't want to do this when you're really low as it takes 7kw away and you might not make it!!You're absolutely right, it can be used on the move, I seem to recall from Miles' charging video it pulls 7kw though. It'd have to increase the efficiency a great deal to make it worth it I should think.
Presumably it's 7kw/hour, so each 10 minutes use will only use just over 1kw?I think if its really cold (- something) and you need to stop to charge, you can run the battery heater for 10, 20 or 30 mins before arriving, obviously you don't want to do this when you're really low as it takes 7kw away and you might not make it!!
not surePresumably it's 7kw/hour, so each 10 minutes use will only use just over 1kw?
You‘re fine, I appreciate the response.Potentially. You could probably hit that for about 70% of the year, maybe even better it. But for the other 30% it'll probably be less. Might average out though.
I've had my car since the 22nd of December and done about 1800 miles, now I do a good amount of motorway miles and my average has been 2.8 mlspkw/h, I think the average speed over that time has been 38mph. I'd say that's my worst case winter consumption.
Like I mentioned earlier though I'm now starting to see 3+ mlspkw/h regularly and twice this week have hit 3.7 on a longer run (Haydock to Fleetwood).
Bit of a long winded answer but yeah I reckon averaging 3.5 over the year is doable with a bit of care.
I can't quite remember what was mentioned in the video to be honest. I'd still be very surprised if it was worth it though.
Might give it a whirl on the way home.
I felt a bit like that as my deal was ending 27th Feb but ovo came through 29pkwh but with a bonus of charging any time 5pkwh so there still is ev deals out there?5p a Kwh charging was, is now 31p, so more difficult to offset.
