RichardC
- May 25, 2021
- Location
- Dronfield, Derbyshire
- MG4 Trophy LR
As far as I can remember the garage replaced the whole steering column and the problem never returned.
Get bit of detective ?️I thought I'd have a go at the other (yellow) column mounting bolts today, I'll leave the bulkhead ones for now.
Took the bottom cowling off the column, nipped up the two yellow ones, tight, made very little difference, they were fairly tight anyway. I noticed while I had the cowl off that when I moved the wheel side to side (not turning) the whole of the tilt clamp was moving as I had it unclamped and between the clamp and the column were some laminated steel plates that separated as I moved the wheel. I believe it's these that are the wrong material (too soft) and are getting squished as any sideways force is put on the wheel.
Anyhow, because tightening this clamp nut too much makes it difficult to clamp or unclamp the tilt mechanism, what I did was set the wheel to my preferred tilt position, clamp it, then because I had easy access to the right hand (green) nut with the cowl off, I tightened the nut nut right up, foregoing the ability to adjust the wheel, and it's now solid, no play, no knock. We'll see how long that lasts, but for now I'm happy, I know exactly where the problem lies, I just can't know for sure why it loosens but I suspect rubbish materials on the clamp.
I can't see the point of having a new column if it's going to be the same a few months later.
The problem appears to affect the ZS EV ( Gen 1 ) model only.Just for information I had my steering column replaced straight away by the MG dealers here in Queensland and the problem was resolved. I was satisfied with the process and speed of repair but wondered how many other MG models suffered this issue and whether or not it was restricted to just the MGZS EV?
Re-aligning the steering geometry by centralising the steering wheel first, then adjusting the tracking is likely to be the corrective action the dealer will take.Good Day
Hello, I would like to ask I change the steering column it needs to wheel alignment?
steering wheel off-center a little bit.
That's not good, take it back.I have the same issue currently, just had the car back from MG after having the steering column replaced, still clicks as much as it did before when turning and now the dash rattles too, nightmare.
Hi Rex, our Uni joint failed. I suggest keeping an eye on it and if it gets worse take in for a warranty fix. Enjoy the ZS EV ?Mine has a faint click, but not every time you turn the steering wheel . Not effecting steering the car at all , so it's direct and good.
So is it worth doing anything with it.
I have seen one person had their botch steering column universal joint collapse, so not safe.
Dealer experiences vary widely, here's hoping yours is good. Please let the community know how you go. There is a section within this site which lists dealers globally and you can add your experience there to help others when searching for a good dealer. CheersThat's great, I have told my dealer about ours, they said just bring it on when I am ready, so hopefully they will be just as good here in Australia
