MG4 EV (air con / fan problem) noise
Enjoying my MG4
EC4N 6NP
MG4 SE SR
My wife and I remain very pleased with our MG4 EV. However, we do have a noise problem when the air conditioning unit is switched on. We reported the problem less than four hours after driving away from the MG dealer and they were as helpful as they could be and replaced the air conditioning unit to no avail. The fault continued and seems to be fan related in my opinion (Depending on the speed the air con is working at). We decided not to have it looked at any further at this time. When we returned to our MG dealer for further repairs, we were provided with an identical car that when inspected, had an identical fault. We then asked to look at other MG4 EV’s on the forecourt, only to find the same fault with all five we looked at. Knowing all the others made the same noise when the air con is switched on, we did not want our car to be dismantled any further. We are now going to chase this up on our first EV service in the hope that other people have reported the fault and had it fixed. We are hopeful that MG4 EV’s will have a factory recall at some stage to rectify the fault. It does seem fan (hitting something ) related in my opinion.
For those that are interested and to aid further, I created a video clip of the noise, that has apparently been sent to MG (China). It probably sounds louder than it is, as a mobile phone picks up the sounds very well. Here is the You Tube link.
Summary- If you have this noise and manage to get it fixed, please let us know, so that we can educate our MG dealer to order the correct spares for repairs. Unfortunately, during our last visit, they lost their MG4 EV mechanic, so this was another reason we did not want it looked at any further, at this stage.
Thanks for reading and am pleased to be on board the forum.
Here’s the reply from our MG service manager following my comments about the noisy compressor:
Yes this are like this. We have had a few enquiries with the heatwave.
Its working harder anyway with the heat we have had, and it doesn't have a
conventional engine to drown out the noise.
Its 100% normal and safe
100% normal it is not ! and safety was never in question. It's possibly a fault, which should be fixed as per warranty... if the noise level is akin to mine, your compressor may be without oil as mine was found to be. If your noise level is high, I would use my experience which has been posted as evidence of a fault which required a new pump to be installed and re-gassed. They should re-gas at a minimum to be sure yours contains the oil required for standard operation.
Again the disparity across dealers is shocking, it's a known fault and if the checked and got it early enough they could save themselves from having to replace parts.
At this rate there are going to be numerous AC systems suffering catastrophic (in terms of that system!) Failure. There is quite obviously a good few out there with this issue, if the forum is a guide of a cross section of cars.
Poor attitude from MG
My dealer said the ticking noise was normal and is the same in ice cars but unheard under the engine noise. Others here disagree.
Depends how noisy it is.
It's normal to hear a noise from the AC and it gets louder as the AC works harder.
What you need to do is check it alongside another MG4 with the same AC settings and see if yours is louder or the same.
My MG4 aircon has always made the whine changing pitch startup sound, but no regular clicking. Not audible inside the cabin either. To be honest I just assumed that they were all like this.
Mine started this loud vibration noise (like the video) yesterday when I turned the air on down to 19°. It's definitely an unacceptable vibration /Grating noise. Definitely not a normal whirring sound. It continued when I got out of the car but stopped as soon as I connected the charger cable. It also stops when switching the heater off
I will contact the dealer and see what is suggested
Thank you so much for replying. I posted a reply on the thread you provided after posting my thread and then stumbling across it. I am currently researching the problem as much as I can. I am fairly confident that it is not oil related due to the type of noise it is making. The main different with PAG100 and PAG45 would be the velocity (PAG100 being thicker) and what I am hearing does not seem to be oil thickness (viscosity grade) related for a number of reasons. If you listen to the video, in my opinion, I think it is more likely to be fan related (fan hitting something - maybe due to the thickness of a gasket or seal). It is also possible that the replacement air con also had no oil in it, but unlikely given the noise I am hearing. If it was not in warranty and a new car, I would take it apart myself and fix, as I am sure it is any easy fix (oil; gasket or something else). I would be keen to know if your issue gets fixed and what action was taken. I hope all goes well with the fix. I am not keen to have my car taken apart several times, hence me reaching out to forums to see if and how anyone got it fixed before taking it back to the dealership. It remains a great car and I will also follow your post with great interest. Thanks again.
Hi, I also have had the same issue. When I returned my MG4 to the dealer I got a report back to say it was a noisy air con compressor and that it was OK. Also, I had the AA look at the car and they confirmed that the noise was coming from inside the compressor. I am not sure that I can accept that this noise is acceptable. I feel that MG should fix this..
Hi, I also have had the same issue. When I returned my MG4 to the dealer I got a report back to say it was a noisy air con compressor and that it was OK. Also, I had the AA look at the car and they confirmed that the noise was coming from inside the compressor. I am not sure that I can except that this noise is exceptable. I feel that MG should fix this..
They can't fix it if it's not broken, but at least you have it on record if future problems arise.
Electric AC is noisy anyway. My MG4 is and my ZS was the same as was my Toyota Prius before that.
It gets noisier the harder it's working, it'll be fine.
My news for you is not good!
The noise got worse and the dealer replaced the complete Aircon unit. This was two days before I set off for Italy. The Aircon lasted 30 miles before it failed to provide refrigerated air. It was a disaster of a journey. The temperature in Germany was 30+°.
All the electrics on the car started to play up. About 25 miles from my planned overnight stop, a red warning light came on warning to stop the car immediately. I later discovered from the handbook that I should evacuate the car! I didn't
The next day the temperature was a lot lower and I continued to Italy
I understand the Aircon cools the battery and the car suffered multiple severe electrical issues after that. Cruise control taking off to 120kph in a multi storey carpark before I switched it off , no satnav, impossible to fast charge which was a major issue with many hours wasted at slow chargers and overnight charging courtesy of obliging hoteliers.
My dealer changed the car but it still cost me Megabucks to switch. Fortunately the replacement is perfect. So, be warned!!
    Votes: 933 77.6%
