Deleted member 10041
- Oct 1, 2022
Your splitting hairs now, reporting of faults go hand in hand with customer care and how they are dealt with
Not really, there must be a post on Dealer and MG service somewhere on here?.Your splitting hairs now, reporting of faults go hand in hand with customer care and how they are dealt with
Your having a laugh, so according to you owners just get to post they have a problem, and what the fix is in this thread. Any subsequent issues they are then having the need to jump to the specific dealer post in the dealer listings to chat about lack of support service etc.Not really, there must be a post on Dealer and MG service somewhere on here?.
This post is about oil leak and source of problem and fix.
You have edited this post at least 3 times now - so I guess the content might change again. Anyway. Not sure where you get you % from? Others might challenge you in the fact that this forum is a ‘negative experience’.My point is they dont need to contact customers over the slightest things that in your mind are a major crisis.
So there was no valid question to answer
This all kinda backs up my theory that using this forum is a negative experience because the 1% of whinger owners make it look like the happy 99% don’t exist.
The 99% are driving their cars and not onntheir knees everywhere looking for oil spots or rippled plastic covers
I give in ...... you win.Your having a laugh, so according to you owners just get to post they have a problem, and what the fix is in this thread. Any subsequent issues they are then having the need to jump to the specific dealer post in the dealer listings to chat about lack of support service etc.
That makes so much sense they are obviously unrelated.
Cheers?I give in ...... you win.
I'm afraid i'm with @Hallix73 I feel a more balanced view of the issue would help members. I feel that a small number of people post an overly negative view of the situation.Cheers?
Some cars do not even have 900mls , remember when they were saying they were overfilled and reducing the amount of oil to 700mls to try to stop the leak.How do you know it's only a small amount of oil though, would you be willing to a 100% say that there will be no detriment to the gear box.
There is only 900mls in there to start with, if the car is leaking over a period of weeks could you say that it wouldn't lose enough to cause any undue wear through the reduced amount.
Remember, for example, MG were initially telling owners such as me to not drive my car over 50 mph when my gearbox had been drained and refilled with 750ml but yet was still leaking. One of the big problems here is the awful communication from MG re this issue and actually false information in many cases. As much as we all respect your undoubted expertise and knowledge in this field it is not from you that the reassurance should come, with respect. This is the reason why we have a nearly 100 page thread on here. Poor communication from MG and poorly executed system to deal with issues. If losing 25% of the oil that the box was designed to hold (onto driveways, roads and into the environment) is so insignificant then it should be super easy to communicate.I am not sure what your profession is and I know you like to comment in a way that knocks the MG4 in a negative way, hence you bought a Megan.
I am a recently retired Marine Chief Engineer and have degrees in mechanical engineering.
I have stripped down many gearboxes on large plants and even on my Triumph Stag.
Unless the box was totaly dry of any oil, so much so the gears could not pick up any oil to splash and form a 'boundary' lubriction between the faces of the engaging teeth then no damage to the gear teeth will occur. So based on the design and quanitity in the box (900ml) almost 1Litre, then I doubt that amount of oil could drip out of the breather to cause a problem.
Like I say once any car has the dripping oil and the new breather is fitted then move on and enjoy the car.
I find it hard to believe that manufacturers routinely design components that need to be overfilled with lubricant and simply expect that some will be lost. Apart from the additional cost and pollution issues, how do they know that sufficient will be retained to avoid damage.
In the case above with the Xtrail gearbox that only needs 0.3l, and oil seal is at 0.4l level why would anyone ever put more than 0.4 l in?
Either more oil is optimal and the design ought to retain that level, or less is required (in which case why ever add more)?
I think given that the car has a 7 year warranty, a lot of the issues aren't deal breakers and I'd agree that its 'probably' fine.I am not sure what your profession is and I know you like to comment in a way that knocks the MG4 in a negative way, hence you bought a Megan.
You can make your service intervals as short as you like, you can't force someone to service their car correctly.Dealers often spout rubbish verbally. They are more reticent to put commit statements to paper where they can be challenged in court,
Good engineering leads to less leaking. Simply adding excess oil is a bodge at best. If there is a significant risk of oil loss or degredation then the service interval should be more frequent.
When I had a range rover Vogue it was listed as sealed for life, but had a drain plug and refill position, had it flushed at 80,000 as it was sluggish changing gears.Service interval for gearbox oil is "Never" AFAIK.
Oh - ok sorry I missed that! Mind you we nearly at 2000 posts now!There are images of the gearbox / motor way back in this thread.![]()
