I had the leak emerge in the first week of ownership, coincided with giving it more welly after I had put 100 miles or so under its wheels , I have the standard breather fitted.
It only amounted to a few spots on the driveway and some staining of the gear casing and inner surface of the wobbly undertray.
If there was more than 20 or 30 ml dropped I'd be surprised, and it now seems to have stopped, no matter how much I cane it.
Really tempted to drain the box's contents into a clean 1 litre jug to see just what oil volume is left in there now that it seems to have settled. The drain plug is easy to access but the fill plug is a little more difficult.
There seems to be no actual level plug, which might explain the factory overfill if the wrong amount was decanted as they claim.
If there's around 900ml I know not to worry, if there's 500ml, might have a problem ?
