AndyL61
- Oct 16, 2022
- Location
- Stoke-on-Trent. England
- MG4 Trophy LR
I intend to change my oil at about 20k so you've reassured me that it really needs doing at around that milage. Thanks . Fireblade in the background? Nice.Just a quickish post ? as I've finally done the diff oil change today, I took a few pics along the way but any questions just fire away.
It was pretty simple just remove the undertray with a million fixings, remove the square drain plug, drain the fluid (& measure) then replace drain plug. Remove the 17mm hex fill plug and refill oil with desired measurement then replace fill plug.
the only issue I came across was my suction oil filler & funnels were useless so after getting oil all over the drive ?, I went and bought a 1l laser mini pump from Halfords which I was super impressed with & had it refilled in about 2 mins from underneath. I've ran out of time as it started throwing it down but I'll get the undertray back on tomorrow but it's done.
soo.......I wasn't surprised to see some evidence of oil leaking underneath but I'm pretty confident it's not recent & was probably from when they fitted the breather or before and filled it with whatever amount of oil then, they were pretty vague on details at the time and it seems impossible to speak to a tech!
basically the oil was black & filthy as expected, I drained exactly 650ml out but I'd say there was probably another 50ish ml came out in drips and on the drain plug etc. As can be seen on the cardboard I left for a while & whatever is clinging to gears inside etc. so I reckon I've had 21k of pretty spirited miles with around or just over maybe 700ml in the diff.
What did suprise me initially was the state of the magnetic drain plug which had shavings all over it, after speaking to a couple of very trusted mechanic mates they've assured me that's relatively normal on any manufacturer first diff change, most of it during the first couple of k whilst it's being broken in and nothing to be worried about & there shouldn't be much on the next one etc. After a bit of research I'm not too worried about this as it seems there right.
basically the oil imo needed doing, possibly it's working harder not having the 900ml in or maybe I'm just anal with oil & it would have been fine forever ? but I feel alot better with it having fresh oil on there, I'll be doing this every 20k as bar the undertray it's a very simple job tbh & reckon it should be done alot sooner than the 72k I believe MG recommended ?.
I put a tad over 800ml back into the diff, I half expect to get a little leak whilst it may find it's 700ml ish level again or maybe that's all they filled it to when the breather was fitted? I'll keep an eye on it anyway and see what happens.
thanks again Macadoodle for the tips etc. Pal.
