MG4 SE motor upgrade from 125 to 150 kw?
I would hazard a guess the the LFP battery runs at a lower voltage and there for its harder to get the peak power out (Volts x amps)
The 0-30mph time will be current limited
30-60 will be power limited (higher motor rpm needs more voltage)
There’s also the probability that the Max discharge (C) rating of the different chemistry’s is different and the LFP can out put more amps at a lower voltage level allowing the extra omph from 0-30 (assuming the weight is nearly the same)
As the SE LR has the same 0-60 as the Trophy
    Votes: 911 77.7%
    Votes: 171 14.6%
    Votes: 90 7.7%
