szymon
Not miffed, having a basically decent vehicle where stuff works makes up for it ?You sound a bit miffed, so just for clarification the early SR and LR only do about 830 miles after a 30 minute charge. ?
If you have a home charger, having rapids near to home are irrelevant. If you don't have a home charger, totally invaluable.Folks, sorry to have caused such discontent on this forum. Happy New Year to you all. But, my real thoughts are; what is the sensible driving range for the LR. If you only charge it up to 80% as per the recommendation and then only discharge it to, let's say, 10% how many miles are you going to go without charging it up again. We all know that there are not enough fast chargers around to satisfy the current demand. Queuing at a fast charger is now becoming quite common. (I am lucky to have 16 within 25 miles of my house if I get desparate, don't intend doing the 8% again!).
Hydrogen is dead as far as cars are concerned. Why use massive amounts of electricity to create green hydrogen which is then compressed and stored in a car, then to use an electrical process to create yep, electricity to drive the car.Ask yourself why there are not more fast chargers? Petrol companies and fuel stations currently have a monopoly over the supply of fuel for cars. Why would they cut off theirs noses to spite your faces? They want to keep supplying fuel for the forseeable future. Bring on the 600 mile range of a hydrogen cell powered car. Hydrogen is the way forward but is probalby 10 years away. So what we are asking is for an EV that will do 400 miles on a single charge that we can get home with without having to use a fast charger that is in limited supply. As I said previously 4.5p at home 70p on a fast charger doesn't make sense.
MG5 trophy Facelift owner.If you have a home charger, having rapids near to home are irrelevant. If you don't have a home charger, totally invaluable.
You are spot on with your thoughts re range etc. and grazing is perfect. If you pootle around town for a week or so the GOM won't reflect range on a M'way and vice versa.MG5 trophy Facelift owner.
I am unlucky and cannot have a home charger. There are quite a few lamppost chargers around me so I am using those for day to day charge. Still a couple of free places around too so I graze charge on those when shopping etc.
I have only use the rapid as a test to make sure I got them to work and on one trip I did recently.
With regards to the above about not charging over 80% I think from what I understand the recommend is not to “leave” it on 100% for any length of time. So if you are doing a long trio charge it to 100% before your go.
In the short time I have had mine I am average about 3.2m/kWh mixed motorway and town. The GOM based on my experience so far seems fairly close to reality. As many suggest and like my ice car I use it has a rough guide. But for quick calculations I use 20m / 10% and seems to be close enough. Obviously I hope this go up once the warmer weather returns.![]()
I don't think you've caused any discontent at all. If someone's looking for an argument they'll let rip, no matter what. All the best.Folks, sorry to have caused such discontent on this forum. Happy New Year to you all. But, my real thoughts are; what is the sensible driving range for the LR. If you only charge it up to 80% as per the recommendation and then only discharge it to, let's say, 10% how many miles are you going to go without charging it up again. We all know that there are not enough fast chargers around to satisfy the current demand. Queuing at a fast charger is now becoming quite common. (I am lucky to have 16 within 25 miles of my house if I get desparate, don't intend doing the 8% again!).
Elsewhere I read that today's wholesale price has no effect on consumer pricing as the suppliers have hedged - i.e. bought gas way into the future - and it's those prices which our tariffs are tied to.The cost of those open 2 instavolt 9.9 miles away is stupid considering the wholesale cost of gas is back to pre Russian war rates.
What it does is give you confidence that if you are getting low AND you are within 25 miles of home, you know that you will be able to find a top up charger to ensure you can get home.If you have a home charger, having rapids near to home are irrelevant. If you don't have a home charger, totally invaluable.
I guess distance is relative, in Norfolk maybe 25 miles (10-15% of battery) is close to home, but not around here.I don't agree with this:
Hydrogen is going to get very green when they install Hydrolisers next to the wind turbines to utilise the excess power generated by the turbines. It will save them having to switch off as they currently do. Don't rule it out yet!
I like numbers
My journeys or rather trips, continue to be short ones.
Today I did a round trip of around 40 miles and managed according to the display got 4.0 mls/kWh.
However, me liking numbers, when I punched the figures into a spreadsheet it calculated it as 3.66!
Difference in Start / Finish % = 19 ( therefore 11.59 kWh used ? )
Distance = 42.4
Therefore mls/kWh = 42.4/11.59 = 3.66
Any thoughts? Am I doing it wrong? Or is the 'car' calculating it differently?
Hydrogen will have it's uses in areas such as steel manufacture, and possibly air travel where it is more difficult to convert to electric, but not for cars or home heating, despite the ridiculous trial that is going to take place in Cheshire.I don't agree with this:
This calculation s something that exercises my little grey cells too. The start and finish % must be a calculation because it's not directly measurable, whereas miles, volts, amps and time are all things that can be directly measured. So, my thought is this: the odometer records mileage, the car "computer" measures amps used and time elapsed, then calcultes miles / (volts * amps * time) to display the most accurate efficiency number in miles/kWh. This assumes that the hv battery operates at a constant voltage for the calculation. If the car's computer is really clever, it will do the calculation of mi/kWh every few seconds and then do an integration calculation. I think it may actually do this, because the display can show instantaneous as well as trip cumulative mi/kWh. And we all thought calculus was a waste of time at school... now we know of at least one real world use!I like numbers
Distance = 42.4
