mykg
I collected the car on Thursday 9th September. Four days later and all is well.
Crikey. I will share this info when I take mine in next week and hopefully it may help them along. Might not be the quick fix I was hoping for thenI'm sorry to hear that you have experienced a similar problem that occurred with my car.
I am not able to tell you what actually fixed the problem with 100% certainty as the last action taken was as follows:
The last action proposed by MG Service Support was to remove the front dashboard and inspect all the cabling. The problem has not occurred again since this action was performed.
So, this may indicate that there was a connector issue, which was resolved during the cabling inspection (ie: removing and re-inserting cable connectors). I really couldn't say as no obvious problems were found.
Since that time (9th September 2021) the car has been fine. No issues.
I asked for a written summary from the dealership, which I have copied below:
Carried out diagnostic into customer fault. Multiple warnings on dash. BCM and CAN Gateway replaced. Fault still present. MG advised to clean all earth points and remove dash, seat, carpet and all interior trims. Check all connectors and pulled each pins on connectors. Built back up and tested.
I hope this helps.
I would say that the problem you have is a touch different, but shows the same fault condition. I'm sure they will find the problem and resolve the issue once and for all.Hi. Sorry for not replying. I didn't get a notification of this. It's permanent, it started one day and hasn't stopped since. No amount of disconnecting the battery of fault resetting makes any difference. No, there's no crackling from the speakers at all.
The car is now with MG and they are convinced it's the instrument cluster that's broken. They have ordered one and hopefully it arrives soon and fixes the issue...
I got this issue on my new mg4 2023I've just experienced a problem which has caused me to call MG assistance. A Motor Fault was displayed on the dashboard in red. It also says consult handbook. The handbook says switch OFF and contact an authorised MG repairer. As I mentioned I have contacted MG assistance and I am currently awaiting recovery. Anyone had any experience of this fault.
Have you booked the car into an MG dealership to get the issue resolved? Is the problem intermittent or is a permanent fault? There was no simple fix in my case, but I documented what was performed at the dealership.I got this issue on my new mg4 2023
