PD0052 update
Are you referring to the PD052 update, or is there another/later update PD0052.
If you are referring to PD052, then yes.
On the 24th of March my car was booked in to replace the light strip on the N/S door, under warranty. In the event, the strip was not replaced, as the wrong part had been received?
I was also informed that there were two software updates, PD052, and PD050, and these would be installed.
I have never experienced the excessive revs problem, but following the installation of update PD052 I AM, Going up a reasonable incline, in a que of traffic, doing 35MPH, the revs suddenly increase to 5,000 and do not reduce for some time. When overtaking the revs go up to around 4,000, but there is no loss of power, and then the high revs remain for some time. I much preferred the hybrid operating system, prior to the PD052 software update.
I was informed that the other update PD050, was to improve the operation of the front facing camera. What has happened is that instead of improving anything, the auto dipping feature no longer works properly, in that the operation to dipped beam is delayed, causing oncoming drivers to flash their main beam headlights. The delay in switching to main beam has increase to around six seconds, resulting in my having to resort to operating the dipped/main beam manually.
I reported this to my dealership, and they said they would investigate when they have received the correct light strip. As the first replacement part took 2 months to arrive, I’m anticipating a similar delay regarding the time scale for the, hopefully correct part, to arrive.
Something to do with breweries springs to mind.
