MichaelJHunt
- Apr 17, 2022
- Age
- 70
- Location
- Gloucestershire - ZS TC LR
- ZS EV
14,000 miles in and 9 months old. SOH = 100%
You need equipment like OBD scanner or OVMS to see SoH.So, when my battery degrades, would I see a reduced soh after charging on my dashboard, ie full charge would show 98% instead of 100 or would I only see this with equipment?
The car will still display 100% SOC but the predicted reportable range will be less as the battery degrades slightly over time / mileage covered and charging sessions performed.So, when my battery degrades, would I see a reduced soh after charging on my dashboard, ie full charge would show 98% instead of 100 or would I only see this with equipment?
Can you expand on what info you are especially looking for on your ZS EV Gen1 ?.how do i get that info up on a 2019 zs ev ?
The info is available using a OBD2 DEVICE and the Android App.Can you expand on what info you are especially looking for on your ZS EV Gen1 ?.
You can only get accurate SOH of your traction battery, if you have the necessary hardware / software to access the HV battery info.
The dealer can do this of course, but is likely to be a chargeable service.
Name of app please also will it work with my 72 plate thanks in advanceThe info is available using a OBD2 DEVICE and the Android App.
Which OBD2 and android app are you all using?
Perfect thanksI'm using the OBD2 Pro Scanner from the play store, the paid one less than a fiver if my memory serves me! .https://play.google.com/store/apps/details?id=com.ovz.carscanner&gl=NO
My Mini OBDII is an old one I bought years ago around 2015 when I was thinking of buying a Nissan Leaf. It works perfectly on the ZS EV.
Shock horror, after 28 months and 5.3k miles, my SOH has started to drop, it's at 99.95%.
My cell imbalance seems to be increasing though. It was hovering around 40mV a year ago it's now at 62mV. It's always been the same two cells that are out. MU04 is always higher than the average reading at 4.224V just now and MU06 is always low, now at 4.162V. All the other cells are around 4.2. ?
Fully charged predicted range still good at 159 miles on the GOM.![]()
Take it you mean rapid and technically your car is always getting DC charge when it Regens full Regen is similar to 40+ kW yes only in short burts but still unbalances batterysnever seen a fast charger in the 21 months I've had it.
From now on, KERS 1 it is then.Take it you mean rapid and technically your car is always getting DC charge when it Regens full Regen is similar to 40+ kW yes only in short burts but still unbalances batterys
