Radio module replacement
Hi Guys , can you send me the Dab files pleaese . I have the same issue with my radio and ny Dealer told me that they will replace the radio module.:(
My car is the Mg Zs Ev 2019
Same problem?
I also had the radio problem with the intalisation error.
nothing downloaded, update... solved within 2 minutes.
just disconnect the minus (2 minutes) of the 12 volt battery and everything works again
I feel ashamed to work you do hard but can I please have the files too. Same problem as everyone else. Thank you in advance
It probably just needs DAB files installing
I have them if you need them
Please send me files. Thank you in advance
I tried this. It did not work for me
Hi there, I have the same problem with the radio. In my case a MG EHS from november 21. Do you think updating the DAB files will work? If so I would like to receive them.
Lambert
I saw
Thank u
Hi sure do you know how to do it
i really interested to know how update the DAB system because the usb key itsn't recognized of the car
Do you help me, please?
Thank u so much
I saw
Thank u
Hi Joioannou
Thank u so much
Hi Joioannou
Thank u so much
You should format the usb to fat32 or exfat. Next you enter to engineering mode and you select the update dab .
Hi,
I have got the same issue since two weeks - maybe someone clouds send me the update file?
Thank you very much
D.
