Rolfe
Moderator
- Apr 10, 2023
- Location
- West Linton, Scotland
- MG4
The chances of me slowing down on a motorway voluntarily are not good. I'd have to be terrified. (OK, I did do Kirkby Lonsdale to Tebay at a steady 50 one night, but I was actually terrified. I think that car went 35 miles past zero on the GOM that night. And it's not as if it hadn't happened before either, except that time I knew I'd never even make Tebay and ended up sneaking into Burton-in-Kendal from the north via a service road. Against a No Entry sign.) Of course if pressure of traffic holds me back, all bets are off. But I think if I stop at Carlisle I'll probably want to stop at Kirkby Lonsdale as well. I do not fancy driving the A65 with range anxiety.
Common sense says stop at Carlisle and aim to stop again at Kirkby Lonsdale. That is safe. Even if Kirkby Lonsdale was trouble for some reason, if I went high enough at Carlisle I could make Skipton without getting too hot under the collar. Carlisle has 12 chargers, and as far as I can see doesn't tend to be terribly congested because it's also close to Gretna which takes a lot of the pressure off. And there are four chargers at Kirkby Lonsdale, and it's generally less busy than Penrith anyway. It's six miles off the motorway, whereas Penrith is right on the motorway.
The thought of only having to stop once, at a charger that can potentially give my car its maximum charging speed (though I dunno, if both are in use together), is so so tempting. I really shouldn't.
Of course if the roads are really congested I might get much better fuel economy than I expect.
Once I've done this once I'll have a much better handle on the real world of how this works in winter.
