Range drops almost immediately after charge
moderatelymod
Belfast
Hi all,
When charged to 100%, display tells me I’ve a range of 167 miles on eco. After about a mile, it drops to about 148.
Apparently my batter cells are at 448 volts after full charge.
Anyone any ideas?
Thanks!
Hi all,
Anyone any ideas?
Thanks!
the 148 is probably based on a calculation of how you are driving since turning the car on. If you have been particularly heavy footed or driving uphill, or you wacked on the A/C then the range is going to drop based on that additional usage.
Is that first mile uphill and you are driving fast?
Hey! The first mile is flat and 30 mph
How often do you use rapid chargers and how often do you balance the battery?
I use rapid charges maybe 1-2 times a week.
I’ve only had it a few weeks, and just balanced it today. Hopefully that makes a difference.
It’s a year old with 17k miles on it, so I guess however the previous owner maintained their battery will have any impact here?
Perhaps run it to under 50% and balance again a few times I read this was the procedure after the original BMS update.
On my car, a 2022 SR model, the range displayed after charge is the range WITHOUT the HVAC.
When I start the car, obviously the HVAC is on, and the range is cut by around 15 to 20 kilometers
Try starting the car and disabling the HVAC, the range should remain the same
Hi all,
Anyone any ideas?
Thanks!
Is the fan on, turn it off and then look at the miles
Hi all, thanks for your replies. As you could probably tell, this post was during my first few weeks as an EV owner.
Yes, the fan certainly made a difference! Greater than I expected.
Balancing the battery also really helped. Before then. I would do well to get a range of 135, but since I am consistently getting a range of 170+ unbelievably, on the same sort of conditions/spends etc..
I tell you what I had on mine. I would do a fairly big trip and the SOC would drop by just 1%. Then a couple of trips later the SOC would plummet from 50% to 39% in no time as if it is correcting itself. Very strange
