JohnV6
- Jan 19, 2025
- Location
- Suffolk
- ZS EV Trophy LR
I'm getting 2.7 currently
That is bad.. maybe turn the heating down a bit and see how that goes.I'm getting 2.7 currently
That shows 3.0 on the last 2500 milesIf you press the m/kWh button twice, it will show the miles per kWh over all of the journeys you have made since it was last re-set. That will be a more accurate indication of your overall energy use. This number will only alter slowly as the seasons or your driving style changes.
MG4 X Power uses a different kinda front motor and is the cause of bad efficiency. Tesla MY LR gives around 4 miles / kWh even in winterGot 3.0 today in my X Power, and driving no different. Still giving it plenty of Beans. So obviously it must be the warmer weather.![]()
Coming home it was absolutly lashing it down with rain. Efficiency was down to 3.9. Shows how just environmental conditions can affect things.Just got 4.2 miles per kWh today, mainly motorway at 60mph from Ruislip to Bletchley Park. ACC, Normal Drive setting, temp set to 20c. So ranges are heading back up.
I have same model and the mileage you are getting is right. Most I have managed on a full charge in winter is 222. In summer I have achieved up to 320 with sensible driving manner.Hi Team,
I have an approx 2 yr old MG EV 4 SE with about 6,000 miles usage. I just wondered what was an acceptable reduced range in the cooler months. In August I was getting 307 miles at 100% charge (ECO), in Oct this dropped to 240 miles at 100% charge (ECO), now in Nov I am getting 210mi at 100% (ECO) -temp today around 8°C, does this sound about right. I did take the car in for diagnostics check but they said battery was ok. TIA
I’m on second MGZS EV. Range drops dramatically in winter for many reasons. Battery temperature being the must relevant.Hi Team,
