Tuareg
My BMW 330D had condensation in the headlights, came and went, non-issue.
My Trophy has really bad condensation tn the rear spoiler and both indicator units. After alot of hassle MG agreed to change them, two days latter it's back. On a sunny day it's really bad, look's a right mess. My dealer has not been of much use telling me to deal with MG directly.
I have the same small cracks all the way over the center light up by the window on my MG4 Luxury from April 2023. I discovered it because there is fog on the inside. I think the problem has been there from the start, as I have seen fog for a long time.The clear plastic on my car has cracked. Has anyone seen this before?
View attachment 18297View attachment 18298
My wife's car has fogged on both rear lamps and the centre bar from day one.Sealed light units are not airtight therefore there is no need for any holes which would increase condensation as more water vapour would be contained within the unit. The fog lights on my z4 are full of condensation because the gaskets have hardened and are no longer sealing.
Your example of the drinks bottle is stretching it….literally ?. The bottle, made from pet, is extremely thin walled at 0.25mm and will flex easily when subjected to an increase or decrease in pressure/volume. A rear light, made from 3mm PMMA, is a well known dimensionally stable polymer, it wouldn’t deform with the slight increase/decrease in pressure caused by the Sun/cold even if it was fully airtight, which it isn’t. Don’t drill holes into light units, it’s an internet lie, it will only allow more moisture heavy air into the light and more condensation, this is the problem with the mg4 light, the seals are not doing their job correctly. It could be a poor choice of material, a design or assembly error?
And what do you think the inherent problem of whole vehicle vibrating at speeds over 70 mph which appears very common amongst owners ? As expected, my MG franchised Dealer's workshop pleaded totally ignorant of such problems and made the excuse that they couldn't replicate it as a road test over 70 mph would be illegal and therefore not possible.Sealed light units are not airtight therefore there is no need for any holes which would increase condensation as more water vapour would be contained within the unit. The fog lights on my z4 are full of condensation because the gaskets have hardened and are no longer sealing.
Your AC charging issue maybe a faulty CCU , which is a known common issue on the 64kWh battery cars.My wife's car has fogged on both rear lamps and the center bar from day one
As others have commented moisture should not be present in a LED cluster
The car is going in next week for a new drivers side light as the moisture has corroded the electronics that drive the LEDS and half of the light is out.Not a 33 grand car?
Just to top things off it will only charge on rapid DC chargers , the AC home charger has stopped working. Maybe a coincidence but this seems to have happened after a recent software update
So, if it's a 'Known issue' THEY are responsible, the Retailer in the first instance and then the Manufacturer.Your AC charging issue maybe a faulty CCU , which is a known issue on the 64kwh battery cars.
Yes it would be covered under warranty if that is the case.So, if it's a 'Known issue' THEY are responsible, the Retailer in the first instance and then the Manufacturer.
It was, but they kept me waiting 6 months until they swapped them out ! Can't blame Covid for that delay surely ?Yes it would be covered under warranty if that is the case.
MG Poole advised this is totally normal as the light cluster there is designed to work that way in cold weather.Should not be happening I don’t think and it’s only on one side but yesterday while at a body shop sorting a repair out for my wife’s car I asked the chap there about it and he said it does happen on some cars the worse ones being Tesla.i will it address with the dealer next week
Les
I think that the light clusters are sealed units , if they were produced on humid days of which China has many then that humidity will be trapped inside and condense on cold days and stay as vapour on warmer days, apart from drilling small ventilation holes which could make it better or worse and lose a bit of value to the car, the only solution is to hassle the dealers or MG .
But seem to be hit or miss , the demo car i got did it , my car which i wash every 2 days with power wash and almos sometimes 4 days in a row in winter dont get itThey are not sealed units and the condensation behaviour is normal although undesirable.
