DBedford
- Apr 12, 2023
- Age
- 67
- Location
- High Wycombe
- ZS EV Trophy LR
£That's not quite true, most hybrid inverters have the EPS (Emergency Output Supply), it's just most installers don't bother to connect them up. The simplest for is to energies a 13amp socket somewhere then items that you wish to power during a power outage can be plugged into it.
My panels and batteries were installed a year ago. My calculations were straight forward, look at the energy price increase (my fixed tariff was ending) my payments were going up from £170 per month to £540. I couldnt bring myself to pay that increase. The quote for my solar 6.7kW panels, 7kWh battery and a 6kW inverter along with energy diverter for immersion came to just under £12k. I took a loan out for 6 years at £206 per month. The real figures of payback can now be assessed having run for a year. My energy bill is actually £142 per month instead of £540, a saving of £398. The £398 more than covers the loan payments so my break even point is immediate!
Since that install, I was still taking some peak rate energy at times due to battery capacity and inverter power. I looked carefully into how to resolve this issue and I ended up making a 14kWh battery with it's own inverter housed in a small tool shed round the side of my house. This AC coupled battery charges from both solar and off peak energy resulting in all of my electricity being free (from solar) or from off peak at 7.5p kWh. The DIY approach is not difficult, all of the info is out there, it's just well hidden by many. Commercial quotes for this level of storage and inverter were in excess of £16k, this cost me less than £4200 and a bit of head scratching.
This is my little toolshed
The lower part has the batteries installed (3 shown here, each module contains 4 EVE cells).
The top half housing the inverter, the BMS and the fuses / switch gear.
This system was switched on 24th December and cooked our Christmas dinner, it has been completely untouched, just sitting there doing what it should.
Several people have now followed the above and are enjoying the same result. If you are DIY inclined, you can build such a system easily and even if you use an electrician to connect up to your grid supply, massive savings can be achieved.
£540 a month on electricity!!!!, yes I can you what has motivated the change.That's not quite true, most hybrid inverters have the EPS (Emergency Output Supply), it's just most installers don't bother to connect them up. The simplest for is to energies a 13amp socket somewhere then items that you wish to power during a power outage can be plugged into it.
This Winter we peaked at £116/months so right now the sums just don’t appear to add up , and plus the fact we are both 66.
